Wir haben folgende Zoppas Gefrierschrank und die passenden Ersatzteile.
Marke Modell Modellnummer
Zoppas PK 311 C O 92059463000
Zoppas PO 22 M 92066400900
Zoppas PUF11220SK 93303101402
Zoppas PUF11220SK 93303101401
Zoppas PO 22 92067219800
Zoppas PO 420 92047881302
Zoppas PO 42 92047867500
Zoppas PO 301 M 92059401600
Zoppas PO 280 92052442202
Zoppas PO 320 92071119400
Zoppas PO 320 92071119402
Zoppas PO 280 92052442203
Zoppas PO 32 92071117300
Zoppas PO 381 M 92060202600
Zoppas PO 28 E 92052412700
Zoppas PV22M 92287771200
Zoppas PV220S 92287265403
Zoppas PV22R 92287266400
Zoppas PV16M 92287667800
Zoppas PO 261 M 92072007400
Zoppas PV05R 92300263301
Zoppas PV05R 92300263300
Zoppas PV25M 92287470700
Zoppas PV 160 SM 92287665700
Zoppas PV25M 92287470701
Zoppas PO 301 M 92059407600
Zoppas PV22R 92287266401
Zoppas PO 381 M 92060207300
Zoppas PO 42 92047865400
Zoppas PO 26 M 92059504600
Zoppas PO 28 92052415600
Zoppas PBF11420SK 92276503101
Zoppas PBF11420SK 92276503100
Zoppas PV 250 SM 92287466900
Zoppas PV 20 S 92277966001
Zoppas PV05R 92300263302
Zoppas PV05R 92300263303
Zoppas PO 28 92052418800
Zoppas PO 220 92067243900
Zoppas PO 221 M 92066402300
Zoppas PO 420 92047881300
Zoppas PO 280 92052442200
Zoppas PV05R 92300262102
Zoppas PO 33 E 92071112200
Zoppas PV16M 92287666800
Zoppas PO 23 KE 92066413000
Zoppas PV22M 92287774400
Zoppas PV16M 92287666802
Zoppas PV130R 93300282700
Zoppas PO 38 E 92053312000
Zoppas PV 160 M 92287666500
Zoppas PV 160 SM 92287665701
Zoppas PV16M 92287666801
Zoppas PO 191 M 92068105100
Zoppas PV05R 92300262101
Zoppas PO 230 92067246600
Zoppas PV14R 93300285400
Zoppas PV05R 92300262100
Zoppas PV22M 92287771201
Zoppas P 200 S 92287870000
Zoppas PO 31 KE 92059463300
Zoppas PV 250 M 92287469300
Zoppas PV 220 S 92287265402
Zoppas PV 13 E 92272062700
Zoppas PK 231 C 0 92066412700
Zoppas PO 191 M 92068102400
Zoppas PA 24 93300320700
Zoppas P 281 CO 92052412100
Zoppas P 0-20 KE 92066501100
Zoppas PV 20 E 92287062600
Zoppas PO 20 KE 92066501100
Zoppas PVF 125 W 92272027700
Zoppas PV 13 92272767400
Zoppas PH 125 VA 92272015100
Zoppas PV 130 92272050100
Zoppas PV 200 92287003700
Zoppas PVF 200 W 92287004100
Zoppas PH 125 VA 92272015400
Zoppas PVF 125 W 92272041000
Zoppas PH 120 V 92272001100
Zoppas PV2500 92845002200
Zoppas PV 220 S 92287265401
Zoppas PO 220 92067243901
Zoppas PV 200 92287063300
Zoppas PA 20 93300300600
Zoppas P 381 CO 92053311500
Zoppas PO 22 M 92067216200
Zoppas PK 231 92066412700
Zoppas P 381 92053311500
Zoppas PO 21 E 92040051100
Zoppas PT 160 93300223400
Zoppas P 331 92071111700
Zoppas PO 400 92040071000
Zoppas P 281 92052412100
Zoppas PO 210 92040051600
Zoppas PO 22 E 95549053100
Zoppas PO 28 KE 92059501600
Zoppas PV 20 S 92277966000
Zoppas PV 200 92287064300
Zoppas PV 200 N 92287003800
Zoppas PV 120 92272026500
Zoppas P 2000 VA 92287000300
Zoppas P 200 V 92287001500
Zoppas PV 240 92285064601
Zoppas PVF 200 W 92287007500
Zoppas PV 13 92272075000
Zoppas P 200 VA 92287002700
Zoppas PV 220 S 92287265400
Zoppas PV 130 P 92273000900
Zoppas P 1120 VA 92272014600
Zoppas P 130 PV 92273000600
Zoppas PV05R 92300263304
Zoppas PK 311 92059463000
Zoppas PV 13 92272777200
Zoppas PV 240 92285064600
Typennummer Ihres Gefrierschranks finden
Wo finde ich die Typennummer meines Gefrierschranks?
Die Typennummer Ihrer Gefrierschranks befindet sich auf dem Fabrikschild bzw. dem Typschild.
Je nach dem Hersteller und der Bauart Ihres Gefrierschranks befindet sich dieses an unterschiedlchen Stellen.
Video Erklärung
Wie Sie auf der Illustration sehen können, befindet sich der gesuchte Aufkleber meist an der Innenseite des Gefrierschranks. Bitte entfernen Sie dazu lediglich die untere Schublade und schauen Sie nach dem Schild. Sollte es sich nicht an der Stelle befinden, schauen Sie in der Mitte des Gefrierschranks ebenso hinter den Schubladen nach.
Welche Nummer auf dem Schild ist die korrekte?
Bitte schauen Sie nach der Bezeichnung Modell- oder Typennummer. Dies ist die korrekte Nummer. Diese besteht meistens aus Buchstaben und Zahlen und kann auch Zeichen wie (-) oder (/) enthalten.
Wie finde ich jetzt die passenden Ersatzteile
Nachdem Sie die Typennummer gefunden haben können Sie diese in unsere Suchleiste eingeben. Sie erhalten anschließend alle bei uns verfügbaren Ersatzteile zu Ihrem Gerät angezeigt. Sie können Ihre Suche anschließend verfeinern indem Sie passende Unterkategoren auswählen.
Beim Hersteller LIEBHERR schauen Sie nach der Nummer direkt unter dem Logo. Hier: GP 1486.
Passt das Ersatzteil zu meinem Gerät?
Damit wir Ihnen die Kompatibilität eines Ersatzteils mit Ihrem Gerät bestätigen können, benötigen wir Ihre Gerätenummer. Diese kann abhängig von Hersteller sowie der Geräteart unterschiedlich bezeichnet und strukturiert sein.
Bevor Sie ein Ersatzteil online bestellen, sollten Sie unbedingt den Geräteabgleich vornehmen, um sicherzustellen, dass Sie das passende Ersatzteil bestellen und sich unnötige Rücksendekosten ersparen.
Was ist die Gerätenummer meines Geräts?
Gerätenummern helfen Ihnen dabei, Ihr Gerät eindeutig zu identifizieren und von anderen Geräten zu unterscheiden.
Bezeichnungen, welche typischerweise von Geräteherstellern gewählt werden, lauten: Modellname, Modellcode, Modellnummer, Typennummer, E-Nummer, PNC Nummer sowie andere.
Brauchen Sie Hilfe beim Finden Ihrer Typennummer, zeigen wir Ihnen bei Ihrem Gerät wo Sie die benötigte Nummer finden.
Hilfe zur Bestimmung der Gerätenummer
Wie führe ich einen Geräteabgleich durch?
Am schnellsten, einfachsten und sichersten führen Sie den Geräteabgleich direkt in unserer internen Suche durch. Geben Sie dafür Ihre Gerätenummer in unsere Suche ein und gelangen Sie zur Geräteseite Ihres Gerätes, welche eine Liste mit allen kompatiblen Produkten zeigt, welche wir in unserem Online Shop anbieten.
Alternativ finden Sie auch die Möglichkeit einen Geräteabgleich direkt auf unseren Produktseiten durchzuführen. Befinden Sie sich bereits auf einer Produktseite, können Sie dort eine Liste mit allen passenden Geräten zu diesem Produkt finden. Sehen Sie Ihr Gerät in dieser Liste, können Sie sicher sein, dass dieser Artikel zu Ihrem Gerät passt.
Jörg Müller vor 3 Monaten
Maik Stachowiak
Maik Stachowiak vor 2 Wochen
Armin Zehetmaier vor 3 Wochen
Edgar Krause vor einem Monat
