Wir haben folgende AEG Bügel-Geräte und die passenden Ersatzteile.
Marke Modell Modellnummer
AEG DBS2300 95007171500
AEG DBS7146 95007172900
AEG DBS200 95007170500
AEG DBS100 95007170400
AEG DBS2800 95007174300
AEG DBS7135 95007173300
AEG DBS3350 95007174500
AEG DBS3340-U 95007175700
AEG DBS3350 95007174100
AEG DBS3350-1 95007329600
AEG DBS3370 95000859200
AEG DBS2800-U 95007175300
AEG DBS3340 95007175500
AEG DBS2300-U 95007172700
AEG HS7-2-6UG 95001472000
AEG DB6130U 95007134400
AEG DB6120-U 95007134800
AEG DB4040 INOX 95007120300
AEG ST5-1-2DB 95000871000
AEG HS7-1-4MN 95000869400
AEG DB1720 95000856400
AEG DB1740 95000856800
AEG DB1340 95007329400
AEG DB1730 95000856600
AEG ST6-1-8EG 95000865000
AEG ST8-1-6DBM 95000863000
AEG ST8-1-8EGM 90019992300
AEG DB7070 95007120700
AEG SPEED107/01
AEG SteamIron148 90008489700
AEG DB 540 61305693000
AEG DB5040 95007121800
AEG DB7020 INOX 95007120500
AEG DB5210 95007135800
AEG DB1100 95007121900
AEG DB5110MO 95007130200
AEG DB8590 95007122900
AEG DB8060 95007124900
AEG DB 404 SE 61304310100
AEG PERFECT DB 403 61304210100
AEG DB1150 95007122000
AEG DB5130CO 95007131000
AEG PERFECT L 1203 61300300000
AEG DB5120 95007122500
AEG PERFECT DB 403 61304210200
AEG SPEED106S/01
AEG DB 540 61305600000
AEG DB7040(00)
AEG PERFECT DB 309 CARAT 61303950100
AEG PERFECT DB 403 CARAT 61304250200
AEG PERFECT DB 204 61303630100
AEG PERFECT L 1002 61300210000
AEG PERFECT DB 401 61304020100
AEG PERFECT CARAT 1203 61300350000
AEG PERFECT DB 308 61303820100
AEG ZAE00120/01
AEG PRSUTSEH/01
AEG DB 510 61305100000
AEG PERFECT DB 401 61304010000
AEG PERFECT L 1001 61300110000
AEG LB1203-1 95007100700
AEG PERFECT DB 308 61303820200
AEG PERFECT L 1002 61300220000
AEG DB8040 95007122700
AEG DB5040 95007121500
AEG BSIZPRES/01
AEG DB 404 SE 61304310000
AEG DB7040 INOX 95007120600
AEG DB 640 61306490500
AEG PERFECT 1203 CARAT 61300350100
AEG DAMPFBUEGELSTATION 95007170100
AEG DB TWO WAY 61304500000
AEG DB1150-1 95007122300
AEG DB6150 95007138600
AEG PERFECT DB 402 61304120200
AEG PERFECT LB 220 61302000000
AEG DB7540 95007123100
AEG DB 640 61306400000
AEG PERFEKT DB 204 61303610000
AEG PERFECT DB 309 CARAT 61303950000
AEG DB5130 95007122600
AEG PERFECT DB 204 61303620000
AEG LD1200 95007120200
AEG A6SS1-82EG 90019995000
AEG ST6-1-4LG 95000864600
AEG ST6-1-6DB 95000864800
AEG DB1740LG 95000864000
AEG DB1710 95000856200
AEG ST8-1-8EGM 95000863200
AEG ST8-1-6DBM 90019992200
AEG ST8-2-8OG 95001471700
AEG DB1350 95007125500
AEG DB1384 95007126600
AEG DB107BU/01
AEG PERFECT DB 402 61304110000
AEG YAE04602/01
AEG DB 401 61304000000
AEG ST7-1-4LG 95000862800
AEG PERFECT DB 308 61303810000
AEG DB 413 S 61304600000
AEG DB 650 61306593000
AEG CLESSUTU/01
AEG DB7520 95007123300
AEG PERFECT DB 414 S 61304790100
AEG DB106BU/01
AEG PERFECT DB 402 61304120000
AEG PERFECT L 1001 61300120000
AEG DB7530 95007123200
AEG LD1200 95007100200
AEG DB5020 95007121400
AEG DB 403 CARAT 61304250000
AEG DB 402 61304100000
AEG DB108BU/01
AEG DS960 95007100300
AEG DB1380 95007126200
AEG PRESUTU/01
AEG YAE04601/01
AEG PERFECT DB 204 61303630200
AEG DB 520 61305200000
AEG PERFECT L 1203 61300310000
AEG DB4050 INOX 95007120800
AEG DB5020 95007121700
AEG DB1370 95007126000
AEG SPEED108/01
AEG ST7-1-2DB 95000862600
AEG DB 403 61304200000
AEG DB7070(00)
AEG DB7521 95007124000
AEG STANDBUEGLER 851 60741325500
AEG YAE11432/01
AEG DB TWO WAY 95007120000
AEG PERFECT DB 309 E 61303910100
AEG PERFECT DB 404 SE 61304300000
AEG PERFECT DB 309 E 61303900000
AEG YAE01432/01
AEG DB5220 95007135400
AEG DB5110 95007122400
AEG DAMPFBUEGELSTATION 95007170000
AEG PERFECT DB 414 S 61304700000
AEG PERFECT DB 204 61303630000
AEG YAE21432/01
AEG PERFECT DB 309 E 61303910000
AEG PERFECT DB 309 CARAT 61303950200
AEG DB5136GR 95007132600
AEG DB1350-2 95007329800
AEG PERFECT DB 403 61304210000
AEG DB6120 95007134600
AEG LD 95007100000
AEG DB7541 95007124200
AEG DB 650 61306500000
AEG DB 530 61305500000
AEG PERFECT LB 220 61302093000
AEG DB5110PB 95007131400
AEG DB7510 95007123400
AEG DB6130 95007134200
AEG DAMPFBUEGELSTATION 61307000000
AEG DBT800 95007131600
AEG PERFECT DB 308 61303820000
AEG HS5-1-6UG 95001471300
AEG A7SI1-62WB 90019995100
AEG SI5-2-6OG 95001471900
AEG DB640 95007121200
AEG DB530 95007121100
AEG SI6-1-6PG 95000870800
AEG DB5210-U 95007136000
AEG SI6-1-2MN 95000870400
AEG A7GS1-74MN 90019994800
AEG HS5-1-4WP 95001471200
AEG HS6-1-2EG 95000868000
AEG SI6-1-4MN 95000870600
AEG SI6-1-4WB 95000864400
AEG DB520 95007121000
AEG EDB5210 91028048500
AEG US7-1-6OW 95000874000
Passt das Ersatzteil zu meinem Gerät?
Damit wir Ihnen die Kompatibilität eines Ersatzteils mit Ihrem Gerät bestätigen können, benötigen wir Ihre Gerätenummer. Diese kann abhängig von Hersteller sowie der Geräteart unterschiedlich bezeichnet und strukturiert sein.
Bevor Sie ein Ersatzteil online bestellen, sollten Sie unbedingt den Geräteabgleich vornehmen, um sicherzustellen, dass Sie das passende Ersatzteil bestellen und sich unnötige Rücksendekosten ersparen.
Was ist die Gerätenummer meines Geräts?
Gerätenummern helfen Ihnen dabei, Ihr Gerät eindeutig zu identifizieren und von anderen Geräten zu unterscheiden.
Bezeichnungen, welche typischerweise von Geräteherstellern gewählt werden, lauten: Modellname, Modellcode, Modellnummer, Typennummer, E-Nummer, PNC Nummer sowie andere.
Brauchen Sie Hilfe beim Finden Ihrer Typennummer, zeigen wir Ihnen bei Ihrem Gerät wo Sie die benötigte Nummer finden.
Hilfe zur Bestimmung der Gerätenummer
Wie führe ich einen Geräteabgleich durch?
Am schnellsten, einfachsten und sichersten führen Sie den Geräteabgleich direkt in unserer internen Suche durch. Geben Sie dafür Ihre Gerätenummer in unsere Suche ein und gelangen Sie zur Geräteseite Ihres Gerätes, welche eine Liste mit allen kompatiblen Produkten zeigt, welche wir in unserem Online Shop anbieten.
Alternativ finden Sie auch die Möglichkeit einen Geräteabgleich direkt auf unseren Produktseiten durchzuführen. Befinden Sie sich bereits auf einer Produktseite, können Sie dort eine Liste mit allen passenden Geräten zu diesem Produkt finden. Sehen Sie Ihr Gerät in dieser Liste, können Sie sicher sein, dass dieser Artikel zu Ihrem Gerät passt.
Jörg Müller vor 3 Monaten
Maik Stachowiak
Maik Stachowiak vor 2 Wochen
Armin Zehetmaier vor 3 Wochen
Edgar Krause vor einem Monat
